Collapsed drains conundrum!
Benjseb
We’ve discovered a slight problem..
We have a courtyard at the back of our property which is surrounded on 3 sides by our property and next doors. The top end is open (highest ground level)
we have about 5 rainwater gulleys feeding into surface water drainage, plus some from next door.
these then flow downhill towards our utility, under the utility and out the other side where they exit the wall as clay pipes and pour water onto a grass verge
Except they don’t. I’ve rarely seen water exit these pipes.
So got a CCTv survey. Told the drains under our utility have collapsed and need abandoning. So the surface water is sat under our utility.
Obviously we need to address this. I’ve been told we can’t line the pipes as they have collapsed.
is there a way of reinstating the drains under the utility (about 2.5m wide, external wall on both sides)?
I’m trying to avoid digging up our utility inside but not sure if there’s any possibility of laying new pipes without doing this / can they be mole ploughed under a house if there’s access both sides?
The only other option is to reverse the drains and run them up the courtyard against the natural fall of the land so it’s an awkward job and will require digging all the pipes up, raising the gulleys, etc.
seeming like a huge job that’s possibly wear and tear so not covered by insurance
Any tips?
Ben
1 minute ago, ProDave said:
Can you not re lay so the drains go around your study and out to the front alongside the study?
the neighbours house is attached to our study unfortunately. So the only “free” place is on the far right of that diagram which is uphill
or possibly at the top of that diagram which goes to next doors courtyard but not sure how happy they will be with our drains redirected through their property
32 minutes ago, PeterStarck said:
Do the existing clay pipes go under the foundations or through them. I had a quote for moling 4m under a lane which was quite cheap with me digging a big hole both sides of the lane.
The ground levels are a bit strange. Level on the courtyard side of the utility but the ground drops about 6ft the other side where the pipes exit.
the actual pipes come out under the DPC (which is 5ft up) but Just above ground level
1 hour ago, Benjseb said:
I'm trying to avoid digging up our utility inside but not sure if there’s any possibility of laying new pipes without doing this / can they be mole ploughed under a house if there’s access both sides?
Yes. You could probably save by digging the holes both sides yourself..
https://www.trenchlesssolutions.co.uk/moling-110mm-drain/
Would depend on what the ground is like.
Edited by Temp
13 minutes ago, Mr Punter said:
Maybe worth CCTV or rod to check the rest of the drains on site.
Yeah I think they all need doing
The report basically said “They’re goosed”
gives me a good opportunity to install some aco drains around the perimeter of the property tho
