10mm Tap Tail O Ring Size
Onoff
I wasn't able to google that info but found whole tails with rings for £3:45 inc delivery from UK seller on eBay. Swap the rings over if not right length?
https://www.ebay.co.uk/itm/10mm-x-1-2-BSP-Fitting-Basin-Monobloc-Mixer-Tap-Connector-Flexi-Hose-Pipe-Tails/162644180159?epid=2202974869&hash=item25de593cbf:g:CJwAAOSw~T9aawZt&redirect=mobile
14 minutes ago, PeterW said:
When do you need them..?? Got a whole box of different sizes I can send you.
Thanks. They're for work. It's for inside some posh £500 taps with built in pir. I took my own "big box in but the closest I had was 7×2.
I then noticed the tap tail ones looked a fraction smaller on the section at about 1.5mm.
I'll just tell them to source a load of 7x1.5mm. Was hoping there was a standard for the tails.
Thanks again.
