RAK
Onoff
17 minutes ago, Onoff said:
@Nickfromwales, your thoughts on RAK wall hung WCs? Turkish I think?
Mate has the Geberit frame same as mine but doesn't want to pay £195 for the same Bernstein pan.
Cheers
Fitted loads of it. Solid, robust gear and no wonky porcelain as you get with the cheaper ( chine....... ) stuff.
I have 4 of them in new build with Geberit Frames. They look good, however I find whenever we flush the toilet some of the flush water splashes onto the seat/floor. I'm not sure if this is something that could be adjusted within the cistern or if it's due to the shape of the toilet and will always happen.
Second time I've heard of that issue!
That DOESN'T happen with the Bernstein (NT2038 model) I have on the Geberit frame.
Cheers
Really good
ive fitted four on ours The seats are really good to fit Just press a button to remove for cleaning
29 minutes ago, nod said:
Really good
The Bernstein has a similar, quick release button.
No overshoot?
