MVHR Efficiency
Hi,
I'm trying to compare quotes for MVHR and its like comparing apples with oranges it seems. Anyhow what level of efficiency should I be aiming at?
The units I've got quotes for thus far range from 57% (NIBE) to 90% (Zehnder)
The quote difference between these 2 installed is £3000 !
More info here:
https://database.passivehouse.com/en/components/details/ventilation_small/nibe-ab-nibe-ers-20-250-1301vs03
https://database.passivehouse.com/en/components/details/ventilation_small/zehnder-group-nederland-bv-comfoair-q350-hrv-comfort-vent-q350-hrv-0956vs03
Any pointers most welcome
80-90% has to be the minimum and I can’t see how one below that is on the passiv database, don’t think it’s on the SAP one which means it’s not recognised for SAP scoring if I understand correctly.
The NIBE one you link has
Heat recovery rate: 79 %
What am I missing?
Also note, like windows, PHI a different way of calculating effeceiency to everyone else so either just use their numbers or the manufacturer numbers but don't try and compare across them
What am I missing?
hi @joth yes my mistake - I was looking at the efficiency ratio.
Whats PHI?
Whats PHI?
Passivhaus institute, that make the rules of passive house and who's database you linked above.
