Bathroom starts !
You want to be sticking that pan to the tiled wall with clear CT1 then leaving for 36 hours before planting your ar$e on it.
Put the pan on, mask the wall then back off and pump in the good stuff. Tighten up and baby wipe the excess. Remove the tape. Go over with a silicone of your choice.
Going to do it all dry first . Now need to read ( well look at pics ) for cutting the waste and supply pipes to the correct length . Plenty of opportunities for fs still ?
Plenty of lube on the flush pipe before you push the pan on, ive had the rubber gaskets/seals slide down the pipe instead of going into the pan. one was so persistent i had to wrap tape around the pipe behind the seal to stop it popping over the pipe end and sliding back.
10 minutes ago, pocster said:
Ok ; seems simple enough .
Measure distance of pipe off wall . Measure distance of pipe off wc .
Cut that difference off the end + 3mm
Been there, done that, plenty o' lube and remove the burrs.
31 minutes ago, pocster said:
Assuming if I fit it all dry I flush it and make sure no leaks . Then take it off ,ct1 , clean it up , leave it for 3 days
You going to replace those two butchered tiles? ?
6 minutes ago, ToughButterCup said:
Its a bit of a struggle on your own: are you using the Geberit cardboard support frame so you can just slide the pan up to the fittings .... ?
Erm no ? Don’t remember ever seeing such a thing
