Internal partition walls Stud work Vs block work
I would love to hear other people thoughts on deciding whether to go for stud work with plasterboards or block work.
The property is a single storey  and I am currently thinking of doing a bit of mix of both.
Dense concrete blocks on:
Walls on South facing side of the building to increase the heavy mass and for the sound insulation between kitchen / living and bedrooms
Studwork on:
Kids bedrooms, corridor walls, reasons for that:
Easier to run any cables, safer for kids when they heat plasterboard wall comparing to concrete wall; It is a lot softer, I've done it myself :)
Mixed filling on bathrooms. For sound insulation I would prefer block work but it is easier to run and hide plumbing pipes in the studwork.
It would be great to see other people opinions.
When it comes to sound insulation, a dense block work wall will always out perform a lightweight wall at low frequencies for a similar thickness of wall.
However you can get some high overall sound insulation with stud work (staggered stud), and better high frequency performance, with a slightly thicker wall.
If services are an issue with block, there is no reason why you can't batten off the block 20-50mm to create a services void and plaster board fixed to the battens.
And if you were battening off and sound insulation was key, you could always fill the cavity with insulation and resiliently mount the plaster board
Edited by Moonshine
I fix MF framing for a living
But I’ve used block to devise rooms off Except for bathrooms and utility on the ground floor
Though it’s a bit of a myth that better soundproofing can be achieved using block
To decide our bathrooms I’ve used two back to back 70 mil studded walls with a 50 cavity
With a loo on either wall you can’t hear the flush from one bathroom to the other
Two 50 mil studs back to back with a 50 cavity will give you better soundproofing than a 100 mil timber stud
  • Like 3
30 minutes ago, AnonymousBosch said:
That's four sheets of PB, Gary?
The plasterboard is only on the outside faces Ian.
The two separate studs make a big difference to the acoustic qualities of the overall wall as there's no direct transmission path for structure borne sound. British Gypsum has a very good website which lists various partition wall types together with their acoustic ratings.
As with everything else, the detail is important eg not putting sockets back-to-back on either side of an acoustic wall. Sealing any air gaps is also v important.
Just now, nod said:
Just two Ian
A lot the work I do is party walls
Factories offices
The sound will carry through dense material
The middle unit is engineering lots of noice and radios
The other two are offices staff
So sound could easy become an issue
18 minutes ago, Oz07 said:
Yeh what about 4" sole and header with 3" studs art staggered 300mm centres. Would this give a superior sound resistance? Can't put nogs in centre I suppose with this way
Ideally you would have two independent  walls so thy sound doesn’t travel
You can brace across the middle using mdf straps
Doesn't say so at the link, but it could well be. I looked into using that but didn't in the end. I'm glad, because the rest of the detailing by the plasterboard contractor was so crap that the green stuff wouldn't have made a dB of difference to the sound-proofing within the house.
No. I had grand plans to do so, particularly around the TV room and between bathrooms. But in the end, the plasterboarding suddenly happened sooner than I'd planned for, so I didn't end up using any additional sound-proofing techniques (other than double-boarding all internal walls).
I'm generally not that happy with the inter-room soundproofing. It's something I'd definitely pay more attention to if I were doing it all again.
Our stud walls are only between two guest bedrooms (one  a part time office) and another around built in wardrobes so I did not priorities it, all others are heavy block, if studs  were anywhere else I would have double boarded and staggered timbers. (I wish I had double boarded or/and resilience bars on all downstairs ceilings.
Thank you for all the contributions.
I find this forum amazing that I ask for an opinion between A and B and the conversation goes so much further and people come with options C, D and E that I haven't thought about. :)
Edited by romario
  • Sad 1
