Amateur bob
Getting electric to plot
31 minutes ago, Amateur bob said:
thanks ill give them both an email, once ive got those two quotes ill need a sewerage plant and then ill be ready to apply for planning?
You need to fill in a form online for quotes not an email, your sewage treatment plant will be part of the planning application along with the arrangements for the run off from it, in Scotland you need permission from sepa to install this
Share this post
Link to post
I still feel you doing it wrong way round
If you cannot get PP on theses sites then every other cost is hypothetical
rough drawing of what you are wanting and  then spend a bit of money on a meeting with planning  would be the way I suggest
Share this post
Link to post
the quotes will be free though will they not? the planners are wanting £200 for pre application advice
Share this post
Link to post
will i need to get in touch with sepa and get their permission before i can make application?
Share this post
Link to post
Yes the quotes are free
Share this post
Link to post
think you are missing the point
get free quotes if you like ,but If you can,t get PP then whats the use of electric and water supply?
If spending £200 makes you uncomfortable
--then forget building your own house
i spent 4£400 on a topographical survey for a plot --just as well cos the one the owner showed on the PP was nothing like correct--would have needed  2days digger to get the levels he showed+ hundreds  in removing spoil---which wold have cost a lot more than the survey cost
Edited by scottishjohn
Share this post
Link to post
No, you would be applying for permission from sepa during the planning/building warrant stage
Share this post
Link to post
out of interest say i put in for outline planning and spent the £400 and it passed, could i then submit for detailed for free or would it be another £400? or am i better just to put in for detailed to start with? thanks
Share this post
Link to post
I can see where the op is coming from, why bother applying for pp if you can’t get the services or if they are going to be too expensive, we would probably never have applied for pp if we’d known that we were going to get a quote of £25k for electric connection but we were lulled into a false sense of security with the pole being in the garden
Share this post
Link to post
You would have to pay again for detailed planning however I wouldn’t advise going for detailed right away as it will cost you a lot more unless you can do all the house plans and everything else associated with a detailed application yourself
Share this post
Link to post
services you can always get at a price --not so with planning  its much more yes or no situation  and if you start going to argue about PP then the cost will make cost of services  seem cheap
Share this post
Link to post
and that will NOT be £400 --how much was your PP christine ?how many thousands ?
Share this post
Link to post
Probably all in with the building warrant and all fees for architect and engineer about £7k
Share this post
Link to post
I,m not trying to put him off --just inject a bit of reality into  the thing and what IMHO is the right way to start
Share this post
Link to post
Yes I do realise this, I don’t know if you’re on a budget there is a right or wrong way to go about it, in our case we identified the prospective plot first and spent the £400 getting outline pp, it wasn’t until we had got the detailed pp that we made the application for water and electric, had we started the other way round and enquired about the services first we would probably never have made the pp application because we couldn’t have afforded to take that amount off our build budget for the services, I think what added to our naivety was the fact that we had two other plots we were marketing and the ea had asked us to get quotes for services and they had come in pretty normal, as it turned out we’d gone past the point of no return by the time we found out!
Share this post
Link to post
i was thinking of using a timber frame company and using one of their own designs to save in architect fees is there any drawbacks with this approach? what other costs are in that 7k? thanks
Share this post
Link to post
the quotes are free though, the planing isnt?
Share this post
Link to post
he's on a farm and will probably get permission with agricultural restrictions for a workers house
Share this post
Link to post
We did that with our first build but we still needed an architect as we couldn’t have gone through the planning process ourselves as complete novices, I think the kit firms still charge for their plans and SE services
the costs in the £7k were , architect, planning fee , building warrant and SE fees
Share this post
Link to post
SE fees?
Share this post
Link to post
