2 minutes ago, oranjeboom said:
Bet you're glad that faff has been completed! At least you have no ceiling in place yet so a bit easier to tape the joins.
Did you end up CT1'ing all the connections or just taping?
Yeah ; another job done .
ct1 on all the solid white pipe stuff - those joints ain’t coming apart ! . Foil tape them aswell - just to be safe !
Best to be safe. Especially if you get some muppet tradesman doing work after you and decides to sit/lean/swing from them!
I won't bother using the illbruck stuff then- maybe that is meant to as a sealant when going through walls etc. Now that it's cooler, I'll force myself into the attic to finish that job I started months ago...
If I've done it - you've got to do it! ?
