My distribution box for the MVHR  ( sometimes called spigot box or manifold) will sit beneath a flat roof , but above a ceiling.
The roof build up from top down is;
  • Alvitra Avalon over
  • 270mm of insulation on
  • some super expensive vapour stuff - forgotten the name - the price was so traumatic
  • 22mm OSB3
  • POSIs above the ceiling build up which is
  • Vapour control layer
  • 25mm insulation
  • 12 mm plasterboard
  • 2mm plaster skim.
There's enough space for  spigot boxes to  sit comfortably under the POSIs. That means they are outside the heated envelope. (just)
The supplier says not to worry : but they would wouldn't they? Everyone has that problem, said the rep,
What do you think?
I think, do you need the 25mm insulation? Is it going to be make a significant different to target Uvalue.
The supplier is probably right, the temperature in the void between the posi's will be very close to room temp. Chance of condensation very minimal I would have thought.
